I have a 1997 Johnson V6 Ocean Runner. (J150exeuc) Has a Michigan Wheel Rapture 14 25 R19 propeller (013066). I believe I slightly spun the prop hub. Rubber not totally ruptured but the spline is not center of the hub and causes a little wobble in the prop. Shaft is straight, check with dial indicator. My problem is I can not seem to find a replacement hub for this prop. Is there a replacement or do I need to buy a new prop?
