am_dew
Advanced Contributor
I am looking for a spare 14x19 LH prop for my standard shaft 270 drive and not having much luck. I thought a Solas Amita 8712-145-19 would work but I called Solas and they sent me a few pics which show that there is a flange which encircles the hub and is about 3/4" higher than the end of the hub itself. This won't work with my setup because I have to use te setup where a lock tab washer is used as shown below and the raised flange will not allow me to access the tabs on the lock washer (F) and bend them into the spacer (C).
Does anyone know of non-OEM prop that will work on the standard shaft 270 drive?
