Hello all,
I'm in the project to swap my 5.7 to 7.4. Boat is 1987 Sea Ray Sundancer 268.
I had cracked my 5.7 block, and prior to this it had some knocking noise, so I'm not very interested to change block and hear the same sound again. During the winter, I've bought 7.4 as non runner, and partially incomplete. Disassembled, found stuck rings on one piston, assembled it back, fired up with basic wiring and left it in my shed.
Now the time is coming to get my boat going again, and I think to put that 7.4 in. There are couple of issues with it, and I hope, that with Your help I'll be in the water briefly.
I've decided to use 7.4 pulleys, but now find out, that 2 of them are different from 2 others. So disassembled pulleys, and now will go for 5.7 serpentine belt pulleys. There's an issue with circulating pump, as it will be driven counterclockwise with serpentine belt. Should I worry about that?
Also I'm unable to find location where to put oil pressure switch.
One set up like that: https://www.google.lt/search?q=merc...UICigB&biw=1256&bih=655#imgrc=tusAR8-zj6v3tM:
comes above oil filter.
But I have another one like this:
https://www.google.lt/search?q=merc...UICigB&biw=1256&bih=655#imgrc=OoRLS-D4n7sPjM:
And don't know where to put it.
Seems all for now.
As I will work on this project everyday, I will post updates and more questions.
Thanks in advance in Your participation.
Seems all for now.
