Problem with Evinrude 40hp 1995
96chevs10
I try to start the motor and i
I try to start the motor and it wants to start but does not actually turn over. What could be the problem. Any suggestions will help! Thanks
"you crank it with the starter
"you crank it with the starter ,but it does not fire,.......................
check your spark it should jump 7/16 of an inch
a strong blue arc is what you need.
check compression,fuel."
