I have a broken pump on an integrated mercury PS pump/reservoir. It looks identical to a standard GM issue. The engine is a GM 350, 1993 model. I would like to keep the reservoir, because the cap is welded on and has a ports to transfer excess fluid to an external reservoir and the PS pump on the other engine. My mechanic suggested I replace or fix the pump and put it back into the same reservoir (shaft broke off internally, so I think replace). I can find pumps at auto parts stores (autozone) that look like they will fit, for about $40-50. I know using car parts in a boat is risky, but in this case is there any difference? Also, if I were to replace the whole pump/reservoir assembly and get a cap with ports, the cost of a GM pump/reservoir for a car is about a third of the cost of a Mercury or Sierra PS equivalent unit ($400). Are these constructed from different materials to avoid corrosion? Any justification for the cost difference?
thanks,
Roger
thanks,
Roger
