I have a 1995 Crownline 225BR with a 350 mag and Alpha Gen II drive. I had incredibly tight steering that I traced down to a bad helm/cable that I have on order. With the cable disconnected I tried moving the outdrive and it wouldn't move. I removed the steering ram to check it and with the flats on the actuator oriented horizontally the cylinder will move and push fluid but when hooked up and the engine running it wants to constantly turn the outdrive to the starboard side. When I reorient the flats to vertical the drive wont move by hand again? Anybody got any ideas on if this is normal or if the actuator is bad?
