Well I did pull it back apart to check this and yes key is intact, still no water, I removed thermostat and nothing, poured water down into block, never forced water out but lot of water running down under engine, started motor and did gargle but no steady water coming out, cracked block possible???? Please don't tell me yes just got this 1 month ago. Going to do compression check now, will update.Key in impeller didnt fall out?
Compresson checks Top to Bottom #1 85 #2 80 #3 70 I don't think this is good!!!!Well I did pull it back apart to check this and yes key is intact, still no water, I removed thermostat and nothing, poured water down into block, never forced water out but lot of water running down under engine, started motor and did gargle but no steady water coming out, cracked block possible???? Please don't tell me yes just got this 1 month ago. Going to do compression check now, will update.
