Popping at idle
Use a timing light and see if it is firing steady on all 4 leads.-----------Have you adjusted low speed mixture needles ?
Ok. So now that I have it out of the water, cowl off, running on the hose. When I give it some throttle and let off, it puffs smoke from behind the switch box, and there is oil down the side of the block. Now I'm nervous
