Plug Wires for 94 ford 50
crestapre
Would anyone happen to know th
Would anyone happen to know the part number for a set of spark plug wires for an OMC Ford 5.0l
I have been looking at various brands but the listings are odd for this year.
"Do you have the model number
"Do you have the model number of the engine?
Post it back here and I will look up the OEM part number.
Also see this link but I think you will need the OEM number to find it there."
Thanks for the help.
I believ
I believe that the model is #50FACPMDA
the serial # T01266157
on a 1994 OMC/Volvo Penta joint venture with twin Ford 5.0l V8
"I checked the BRP site and it
"I checked the BRP site and it gives individual PN's for each wire including the coil wire. Go to this link http://www.evinrude.com/en-US/Accessories/Introduction.htm once there, on the right side select engine diagrams (will open a new window) Top left pull down select Stern Drive, then select year, engine size and finally model # then you can see parts for each section."
Great link Bob! Thanks.
I don
I don't know how much the wires will cost from the dealer but at least I know that I can get them.
Any ideas on an aftermarket set?
thanks
"Andrew, no I don't have t
"Andrew, no I don't have to OEM # for the "set".
The OEM wires are listed individually on the BRP site that boatin_bob had provided.
The 18-8802 has been popping up in my research as well. I believe that is a Serria #
Thanks"
