Please help
jbizzo
Ok I started with the problem
Ok I started with the problem of no spark. Changed out the stator on my 1987 DT150 SS and had it running for about 10 min went to lake to run it 5 days later and no spark again? Can anyone please help me with this or what to try?
Engine control unit & CDI
Engine control unit & CDI Box. Need to check if stator coils are puting out correct signal. if not most likly the engine control unit is bad. What is the part # on ECU its behind electric cover. I have a used one but need engine # 15001F-XXXXXX I think part # for ecu is 32910-87D40 DF150S EFI
This is for the DT150 SS the t
This is for the DT150 SS the two stroke model if this is the part you have can you give me a better discription of where to find the numbers you need? Thank You.
