Please help
I have a Johnson 2002 4 stroke 15hp and I cant get it to idle. The motor is like new. It runs perfect but I cant get it to idle. I have cleaned the carb twice.
I have played with the spring loaded idle screw but then it revs too high. Is there another low idle adjustment?? Alos, there is another spring load screw close to the motor and attached to the throttle linkage on top??? Not sure what that one is for??
Thank you so much
Thank you so much
