"1982 AQ125/275 I`m installing
"1982 AQ125/275 I`m installing a Pertronix electronic ignition and 3 Ohm coil. Using Pertronix instructions, to check if I had a resistor, I had 9.5 volts with the old Bosch coil. This indicates I have a resistor, the wiring diagram also shows a resistor. I have looked everywhere and can`t find the dadgum thing. I did the same test with the new Flame Thrower coil and had 11.2 volts. Can anyone tell me where the resistor is located? Or, how do I tell if I have a resistor wire?"
