handymanrichard
<h1 style="box-sizing: border-box; padding: 0px; margin: 0.67em 0px; visibility: visible; line-height: 1.1; font-family: Tahoma, Arial, "Roboto Regular", "Helvetica Neue", Geneva, "Lucida Grande", Verdana, sans-serif; color: rgb(51, 51, 51);"><font size="3"> 1993 Johnson 115 hp VJ115TLES</font></h1>Cylinder 1&3 overheating. Overheating alarm working and #1 cylinder is in fact way to hot.<br><br>I have had the cylinder heads off several times and all looks good inside the water jacket. The rubber deflectors are as they should be.<br><br>I have taken off head covers and they appear good.<br><br>New head gaskets sealed and torqued per service manual instructions.<br><br>No sign of gasket leaking cylinder pressure into water jacket. Checked heads and block with straight edge.<br><br>Checked water pump housing, impeller, seals, tubing connect o ring, gasket seal under pump. All seems correct.<br><br>Went through thermostat housing replaced thermostat and inspected all components and all seamed as they should be.<br><br><br>Does anyone have idea of what could be the cause? Am I missing something?<br><br>Or is this a inherent problem with this engine?<br> <br>I am at a loss. <img src="images/smilies/confused.png" border="0" alt="" title="Confused" smilieid="10" class="inlineimg"><img src="images/smilies/confused.png" border="0" alt="" title="Confused" smilieid="10" class="inlineimg"><img src="images/smilies/confused.png" border="0" alt="" title="Confused" smilieid="10" class="inlineimg"><br><br><br><br><br><br>
