I am having problems with my 2007 5.7 merc. It is running hot when it starts and idles, you can't hold your hand on top of the heat risers after about 1-2 min. of idle. I have replaced the impeller the water dist. hsng.(broken) and the thermostat. I have also had the engine out and replaced the crank and bearings(#7 rod brg gone). Upon removal I found that someone else had recently had the exhaust man. and risers off, I replaced the riser gskts the same way they came off but am now wondering if they were installed correctly. Does the small hole face the front of engine or the rear. any other suggestions? The boat only has 170 hours on it never in salt water. Thanks
