Jason Mann
1996, Johnson 115 Cross flow. 65 hours on new power head. Overheat alarm (steady tone) turns on and stays on after approx 5 minutes of motor running. I dropped the lower unit already, water pump looks brand new. Pulled thermostats and tested them in hot water, they both opened at approx 170 degrees. Ran motor with thermostat cover off and water is flowing through block. Pulled temperature switches and tested them in hot oil, received continuity from sensor to wire at approx 207 degrees. Now I'm stumped. Somebody help, please!
