these the parts your referring to?check thermostats
Sorry I was tring to upload a diagram of the cylinder block assy that shows one on each side / upper area. New to this abit. Which side would most likely be the bad thermostat????????????????????
you always do both
hi, check the both thermostat and check the water pump. because water pump impeller has no warranty. I suggest run both engines at same rpm and check the temperature.
