I have a 1998 Johnson 60H outboard (VRO). The last time I used it was 2018 and did not close the VRO hose valve to shut off the oil. A couple of weeks ago I tried to get it started (New Battery) and it would only turn over once. Yesterday I tested the starter and it worked fine. I decided to take out all of the plugs and it turned over just fine. Alot of oil was coming out of one of the cylinders (Bottom 3rd Cylinder). So, I kept turning if over by hand until there was just a little oil coming out. I put the plugs back in and now it turns over just fine.
Is this something that can happen if left sitting for a long time with the oil valve on? Is there something I can do to prevent this in the future other than closing the valve.
Thank you
Thank you
