Hi all.
I have had some problems with my 8hp 2003 Johnson outboard. It ran ok to start with but then wouldn't go above half throttle. I checked the linkage which was all fine, changed the fuel pump, and rebuilt the carb. Took the boat out again and still the same problem. I decided to check if the timing was out by advancing it a tiny bit and this then got the engine running full throttle again so I'm pretty sure it's a timing issue. My question is, how do I set the timing myself? Is it something I should take to the proper mechanics to sort or can it be done myself?
Thanks everyone
Thanks everyone
