Outboard continues to Wobble and shake vigorously
Moller000
I own a 1992 25Hp Cv Yamaha outboard and as of the last 2-3 weeks it has begun to wobble and shake quite loosely, where the engine housing meets the top of the leg. I've tried tightening all screws, bolts and the rubber shocks but it still continues to wobble.
Everything seems to be in good order, the exact location of this movement is coming from the swivel point between the engine housing and top of the leg
I acquired a 2004 F60 that had failed (upper) engine mounts. I think your prior suggestions are right. If they are, your steering should be pretty sloppy. Replacement is basically 2 bolts. But, you must remove the engine block to get to them.
