Only running on 3 cylinders
2006charger
"I have 99 merc 115.before win
"I have 99 merc 115.before winterizing i could get 5200 rpm and very good acceleration.Now acceleration is poor and i only get 4700 rpm.Iran the boat to clean out the fogger,changed the plugs.The number 4 plug is spotless,while the other 3 are a bit dirty.there is spark to all plugs and the compression is good.Tested by local mechanic.Any ideas on my problem."
sounds like carb problem. DO N
sounds like carb problem. DO NOT continue to run in this condition. you could do serious damage.
"if you rebuild carb, keep in
"if you rebuild carb, keep in mind upper, and lower carbs are different. may take a different kit."
"Thanks Ihope that is the only
"Thanks Ihope that is the only problem.What activates the #3 and #4 cylinders.Also,I ran half of last season like this before I eliminated a problem with fuel feed . how hard is it to rebuild that carb"
"Idle jets on #3 and 4 are ver
"Idle jets on #3 and 4 are very small, only feeding enuff fuel for cooling and lubrication at idle. At higher rpm the 4 carburetors operate the same."
