fiveoclocksomewhere
1987 350 cruisador in a 34 sea
1987 350 cruisador in a 34 searay v drives.engines run fine for the first half hour.after that when tring to get on plan the starboard engine lags behind for about 1-5 min.most times it will then catch up with the other engine.you can hear the engine start to pick up speed and the rpm's then come up to match the other engine.i have replace the fuel filters in the carb as well as the water/fuel seperators.i have exchanged coils from one engine to the other and the same engine is still at fault.i first though this was a fuel problem but am not so sure any more.could this be a vapour lock??the engines were to be tuned up a year ago before i bought the boat.any suggestions to speed up the fix would be appricated.
