SuperT
My buddy has a irritating problem with his fuel connector. When he plugs it into the tank it will sometimes bleed gas out of one of the two pins that get compressed when you lock it on the tank. As you look at the male connector on tank, it's the right one next to the fuel supply connector. Problem is still there with a different female connector also.
I've always thought that one was for venting the tank, but when he squeezes the bulb it'll start to leak there. And yes, the bulb is connected correctly. When he switches to his other tank no leak. What the heck is going on here??
When I pulled the gauge/connector assembly off tank and pushed the above described pin in, the fuel would drain out the suction tube. I just cannot connect the dots as to what the problem is. That connector seems to be very simple.
