andrewmaeyaert
"Hi,
I recently purchased a 1
"Hi,
I recently purchased a 1979 cobalt 18' bow rider (tri-hull)equipped with a ford 351 and a 800 series stringer. the previous owner cracked a cylinder head in the spring of 08. Then he let it sit all summer, and all winter with out winterizing it. So now, I believe I am dealing with a completely shot engine. I think this because when the he cracked the head, water got into the oil. so I think the internals are shot due to sitting water, also he did not winterize the engine, so I’ll bet the block is cracked.
Anyway... I decided to buy a mid 70's 351w out of an f-150 to use as a "core" to build off of. What I am wondering is will this work? Are there any differences in the truck block, and marine block? I would be putting all of the marine accessories on it such as alternator, and carburetor. I was also wondering how good the marine engines were built. i.e., how good are the intakes, cams, and heads. My plan was to mildly build up the engine before putting it back in the boat. (cam, intake...) my projected power output would be somewhere in the upper 200's to low 300's. Can the outdrive take that kind of power? I am new to the omc stringer drives, any info you might have to offer about these drives, or ford engines would help. Thanks for your time, and thanks for reading. I hope to here back form you soon."
"Hi,
