slimjohnson
Has anybody tried to remove whatever is inside the remote control that stops the throttle from moving while the fast start lever is raised. Its hard to tell looking at a parts diagrahm. I dont want to take the thing apart if its pretty much impossible to do. 83 model side control for a 140. I have a jet foot. I am aware of why it was designed this way. with the jet and a cold natured motor in a lot of river current it would be very helpful to be able to get on with it and lower the fast start after you are moving. There is no gears to tear up in a jet so its not like drop shifting a boat with a regular lower unit. If the interlock is real hard to change how bout wiring around the starter disable with throttle raised. Any thoughts.
