fullthrottle63
"Greetings to everyone,
I hav
I have a 1989 OMC Cobra 5.7 that runs bad. When I uncovered the boat this season and changed the oil and filled the empty gas tanks, it's started right up and purred like a kitten. I figured I should give it a tune up for the heck of it. I have a prestolight ignition. I changed the plugs and gapped them, changed the points, condenser and router. I also changed the rusty coil with a Sierra Part #18-5437. I gapped the points at .0016. One page of the OMC manual it states.0016 gap and another page stated .0018 gap. I started up the engine and once again, it purred like a kitten up to 3,000 rpm with the water muffs on. Later on that day, I started up the engine and it ran like crap. It wouldn't idle or run past 1,200 rpm with the throttle open. It's getting plenty of gas. I checked the plugs and they look fine. I cranked the engine over and grounded out a spark plug. It was orange in color. Next I checked the points again to see if they moved. It still was set at .0016, next I reset them at .0018 and it ran even crappier. Not sure what to do. is it the wrong coil? It states it uses an external resister, allthough I don't see one. Am I better off just buying a points coversion kit with a flam thrower to solve the problem?? Help!!!!!"
I hav
