Mikey N.C.
Advanced Contributor
Have a skeeter 1989 with serial # cc v 4 1988 cross flow 90hp, motor first came in for loss of power. First compression test .125 on 2-4 an 130 on1-3. found that. Orange / blue strip to # 2 was under readings . cylinder was not hitting, New cdi box, Motor runs great but coughs down low near exhaust plate.. He fished a tournament last week. Got motor lifted power head, the lower crank round cap at bottom 4 inside bolts for bearing retainer are missing and outer 6-8 are back out half way. I have a cr 115 cross that I'm going to swap. Now cc. 88' block has 4 return oil vacuum lines. One from block and one from inspection plate( exhaust plate) on both sides. The cr has only 1 from top half between 1 and 3 ,do I eliminate the other 3 ?
