"Just traded for an old Hurric
"Just traded for an old Hurricane deckboat.
Engine got hot and cracked the heads. Guy installed (I believe)231 buick heads but said the valve train didn't oil so he tore it back down and got tired of messing with it.
He said the 231 oiled thru the pushrods and the boat had solid lifters and oils differently, he doesn't have the old heads.
Is this true? is there a way to modify the heads?
Even better yet, is there an fairly available automotive engine that is pretty much a direct swap, (bellhousing , mounts, water manifolds fit.) and if so how about flywheel,
Search on the internet seems to indicate that a GM 3800 might work (in a jeep) but how about in an OMC and if so how about flywheel,(newer evenfire)"
