While in the process of chang
While in the process of changing my water pump I noticed that after removing the propeller and tilting the lower unit back down that an oil and water mixture (about a tablespoon full)started running out of the housing where the prop shaft is located. When I drained the oil from the gear case it was as clean as the day I put it in but I only have about 10 hours on it since filling it. I would like to think this is normal but something tells me it's not. What is the problem? Thanks...Bob
