I need help again..
318 engine, Port sid of Port Engine. After 4 hours and second oil change lifters started making noise. Heads, Valves and Stems were redone.
I removed valve cover and found oil only coming out of 3 to 4 of 8 oil port on rocker arm. I blocked working ports and oil went thru non working ports.
Oil Pressure is fine.
Any suggestions? You all were very helpful on another problem.
