I’m restoring a 1958 Johnson Seahorse 10
(QD-19) with an oil/water leak coming from the water bypass cover.
I’ve replaced the propeller shaft
gear case/bearing seal, o-ring, rope seal, and used gasket cement before reinstalling.
Also replaced was the shift rod o-ring, the seal and gasket under the impeller, both
o-rings on the impeller housing spacer, and the water tube grommet. When I remove the gear case extension, it’s pretty messy in there too. Could I have done something wrong or missed something altogether? Thanks for the help.
