I have a 2007 yamaha vz200tlr, just replaced the water pump with a oem water pump kit. Reinstalled the lower unit and found after tightening down the bolts per specs and found I can't put it in gear but when I back out on the bolts a little it goes into gear fine but this leaves a gap between the motor and the lower unit.
Any suggestions?
Any suggestions?
