The engine was running sweet as you like two days ago, went to start her and it wouldn't fire up. This is what I've done so far:
BF9.9hp Honda outboard, pull start from 1996. It was working fine but chugged to a halt and won't restart. I've taken the fuel filter off and when i squeezed the fuel bulb fuel shot out of the filter, the right fuel is in the tank and clear, the tank is nearly full. Took the spark plugs off and they weren't corroded but they weren't overly wet either, considering i have been trying to start it for a couple of days, I pulled the starter string with the plugs out and no fuel was ejected from the spark plug hole, when the spark plug was placed against the the engine and the starter pulled there was no spark, but when I pulled the starter string as the spark plug was being put against the engine there was a bright blue spark arcing from the bottom of the spark plug to the engine. There is a 15a Fuse on the motor but that is intact. the engine turns over when the starter string is pulled but it doesn't sound like it wants to even try to start.
If anyone can offer some advice as what to try next, i would really appreciate it. Thank you.
