infinityron
folks....this is actually about my Mercruiser 7.4 mie w Hurth trans, but I don't see a section for Mercruiser MIE. It's close enough to Crusader 454 to ask this distributor question........yesterday I was going to check my timing on starboard engine only because I wanted to make sure it was still where I wanted it. But with it idling at about 800 rpms, I inadvertantly knocked off the coil lead from top of coil and of course killed engine. But when put the lead back on top of the coil, now engine just cranks like no spark. Thinking the coil may have shorted, I swapped coils port to starboard and the port side coil now connected to starboard engine still resulted in no fire. The starboard coil now on port, started the engine. So.......any ideas on what has happened? These distributors appear to be factory original 1990 but no identification on them. My parts manual gives me a part number and the illustration looks like the same units I have. I do not see points. There is a small white plastic sensor in the distributor that bears "microswitch" lettering and has two wire leads connected to it on outside of distributor.
help appreciated
help appreciated
