is it possible for a power-pak to go bad and supply spart to the upper cylinder and not the lower
I just repaced the coil and wire on the port side lower cylinder (it was the old style coil with an intgrated wire that was frayed)
its a 1981 evinrude 115 HP
it will start but it will not idle. so I started searching for problems and found the lower port side plug clean from not firing
