I have a Japan made Mariner Ser#667AS015210 1978 8hp 8M two cylinder two stroke.
I have spark on bottom cylinder but not top.
When I switch the wires leading to the coil with the other one I have spark on top and not bottom cylinder. So the coils are both good. Tested with spark indicator and is very very weak on dead cylinder. So getting a little but not much.
I have pulled the flywheel and inspected the points. The cylinder with out spark has a white color to contacts where the good one looks blued.
I have cleaned the point on dead cylinder with match book striker and blew out with air. But did not help.
Is there a way to test the pick up coils on the mag? I see one is listed as a 80w coil and the other called primary(the one hooked to dead cylinder).
Would a bad condenser do this?
The condensers and points are still available but pick up coils are not.
Thank You
Ray Trimble
Thank You
Ray Trimble
