Here the situation bought the boat a couple months back. I replaced fuel filter, plugs and wires, oil and filter. I fix so other minor issues with help on this forum. I took the boat out ran great. I took the boat out again for a 3 hours everything was great until the motor died. I pulled back the engine cover and there was a lot of water in the engine compartment. My sump pump all of a sudden quit working on me. I took a cup and shoveled the water out the boat. I went to start the boat it would turn over but wouldn't start. I had a gentleman tow me back to the boat dock. I wait a couple day that way the engine and all electrical component could dry out. When to start the boat on muffs would only turn over but would start. I figure either a fuel or spark issue check fuel everything was OK. I check to see if I was get spark. (NO SPARK) So I was thinking that it could be something to do with the distributor of coil unsure where to look and check to find problem. I another possible is maybe a main fuse unsure where to look and check to find problem. If anyone can shed so light and insight on this issue, it would be greatly appreciated.
p.s. If you need anymore information please let me know.
