No spark 88hp
searay123
"I have a 88hp spl motor , mo
"I have a 88hp spl motor , motor has four seperate coils that go to the plugs , turns over yet no spark . any sugestions ?"
"Are you testing the spark wit
"Are you testing the spark with all of the spark plugs removed? If not, do so.
If still no spark, disconnect the large RED electrical connector at the engine, then test the spark again. Crank the engine by manually engaging the starter solenoid.
Let us know what you find."
What do you mean by all the plugs removed, like have them out of the engine with the plug wire still attached? Or should i de attach the plug wire
There is no way you could have 4 bad coils.----Step #1 is to charge the battery and load test the battery , even if new.----After you do that more help will follow.
