Hi All,
Im new to these older larger outboards but looking for advice. I purchased a Glastron V156 as a bit of a project. It was fitted with a 1986 75HP Merc in good condition. Started straight away from cold stopped and started a few times no issues, idled perfect. Towed it about 600miles (1000kms) home no issues smooth roads.
Went to start it at home a few weeks later and some how it has lost spark on cylinders 2,3 & 4. I assumed it was the trigger plate as when I took the flywheel off one of the wires had been replaced.
Still no spark. I have done the following
1. - swapped the wires on the low voltage side of the coil and spark will move with that so no coil issue.
2. - Moved the cylinder one wire to position 2 on the switch box and the spark moved to cylinder 2.
I will be checking the resistance on the stator tonight but if that has gone "belly up" wouldn't I loos spark on all 4 cylinders. Also can stators just go like that, or is there another issue which could cause that.
Thanks in advance.
Leachy
Thanks in advance.
Leachy
