"I have a 1989 Four Winns with
"I have a 1989 Four Winns with a 2.3L (Ford) OMC Cobra. It has run excellent for the 6 years I have owned it, pulling skiers, tubers, etc.
Last year it developed a 'hiccup' at cruising speed. The engine stumbled for a brief second and then continued. The problem got worse over time so that it was happening every 20 seconds.
While trying to resolve the hiccup I have replaced the spark plugs, plug wires, distributor cap, rotor, points, condenser, fuel/water seperator and coil. Reset the dwell, idle speed and timing.
The boat continued to run poorly.
I took it to a professional mechanic and he swapped the points for another new set and set my timing at 8 BTDC. I had it set to 10 BTDC. The problem wasnt resolved and the boat was noticably sluggish. By the end of last year, the boat began to bogg so bad it would barely plane.
This year I took it out and confirmed the same behavior. I had the carburator rebuilt and still the boat has no power.
I checked the ESA, after spending hours reading through this BB. It seems to be functioning correctly. If in nuetral at 1200 rpm I manually engage the switch, the rpm's are cut way back. If however the boat is in forward gear and turning 3500 RPM, activating the switch has no noticable effect on RPM.
The engine starts easy, idles nice and with no load (in the driveway with the muffs on) will rev up to 5000 RPM with no problems. Put it in the water and it will not accelerate enough to make the boat plane. It wont rev past 3000 RPM and occasionally backfires.
A fellow boater suggested it may be the outdrive (upper bearings seizing)and not the engine. I checked the oil level in the outdrive and it appears normal.
Any ideas what else I could check? How do I verify if it is the outdrive?
Please help, summer is short in Michigan and this one is getting away from me."
