no power on full throttle 125 hp 1988?
toddy85
Hi i have a Bayliner capri with a 125 force outboard 1988?
When i put full throttle on the engine dies down and won't go over 5mph
the boat did back fire a couple of times but started ok. Also some fuel was coming out the carbs, any ideas as to the problem, cheers toddy.
Re: no power on full throttle
Possibly the backfire blew the fuel pump diaphram.Or even the reeds.
Do a compression/spark test.Then check the fuel system.
Check these things and post your results.J
i have the same boat ,motor and problem i replaced plugs and ignition coil packs still not moving i lifted it out of the water with the motor down and it seems i have a fuel leak and the motor does sound like its not getting enough fuel any suggestions out there i dont have the manual so i cant even diagnose it
Junior219 You should start your own thread.Go to the library they have or can get the manual to start you on the right track.
Do what I told toddy and post your results.J
