alright a week about i was out
alright a week about i was out on the lake as im travel down the lake my boat starts making this cluni noise every so often as though its skipping out of gear ... then finally right as i am about to put her up its like it just completely went out of gear... so i checked the esa and interruptor but was told if you unplug them and it then shifts then thats the problem did that not shift in forward. then i tried to remove the shift came and manually shift it ... now when i try to do this it will not go in to forward its like i only feel it grinding on another gear but can not get it to slip in to gear. Sorry ever since problem started i have always been able to go in reverse. So i feel as though i have ruled out eletrical but dont know if i should start ripping the lower unit apart looking for a gear with no teeth or what... Also What should i look at that would pertain to the mechanical shifting like clutch dog etc... and where is it located?
