Catfishtop
The Guy working on my motor seems to know what he is doing but is he doing something wrong? here is the problem check the stator all good numbers with his meter,checked the Trigger was very weak on two of the wires checked replaced the trigger all good numbers now we swithch out the switch box with two other boxes still the same problen no fire on botttom two cyclinders,did some wire switching wit top cyclinders got fire to bottom, telling me that the box is bad, I noticed he had removed the wires from what he called the rectifier,he also didconnected the main wire bundle from the motor to the ignition area, he used a hand held device to turn the motor over, would the removal of the wires from the rectifier cause the bottom two cyclinders not to fire? whould it cause the switch box to burn out on the bottom two cyclinders? HELP!!
