Shado
Hi everyone,
My name is Bob and I recently purchased a 1978 IMP Aztec with a OMC 225 305 powerplant, and a 800 sterndrive.
I have owned several outboards before, but I never owned a inboard/outboard until now and so a lot of this boat is new to me. I am very good mechanically, and have built several racing engines for my motorcycles.
I got the OMC 400/800 manual with the boat (lucky me) and so I have pretty good documentation for whatever is to come.
I started up the engine when I got the boat home using the ear muffs, and the engine sounded smooth and strong. The stern drive moved up and down without issue and the steering mechanism worked perfectly. and I thought I was good to go. I went ahead and gutted the boat, and reupholstered and carpeted the interior. I made schematics of the wiring while the boat was "*****" for future reference, and verified all the gauges, and electronics on board functioned.
I finally took the boat out yesterday to see if it would float - it did.
BUT...
Once I started her up in the water, I put her into reverse to back away from the boat ramp and cruise to the dock where I had my granddaughters waiting to join me on the inaugural cruise.
...nothing happened...
The shifter moved smoothly into position but there was no thrust. Hmmmm...
I cranked up the trolling motor and backed the boat to deeper water so as not to run aground and cause any prop damage. Once I was in deeper water, I put her into forward and the same thing happened.... No thrust.
The guy I brought the boat from had told me that he used it this year and it had no problems. He was moving to Costa Rico and could not take it and so thats how I came to purchase it from him. He is now no longer here and I am feeling a little ticked off that he lied to me.
But I digress...
I used the trolling motor to putter around the lake so as not to dissapoint my grandchildren, then loaded her back up on the trailer and headed home.
I got home and immediately started searching the web for whatever info I could find on the OMC 800 stern drives to see if I could find a hopefully easy fix.
After much study, I find myself no more educated than when I started. I am humbly asking for some help in diagnosing and repairing whatever problem is plaging my boat.
I have turned the key on and put the boat into forward gear. When I try to turn the prop in this state, it will not move forwards or backwards. When in neutral, the prop turns freely. When in reverse, the prop turns 1 click at a time in one direction, and not at all in the other.
I checked the pulse module for the electrical shift assist and it is functioning correctly. I replaced the prop with the spare that came with the boat with no change to the problem.
The motor does not overheat so I am pretty sure the impeller is working.
The ball gears are engaged and turning when the engine is running and do not have too much wear on them (I raised the engine a little while it was running to verify this, then tilted it back down)
At this point I am afraid that I am going to find out that I have broken gears or some other equally bad mechanical issues with the lower unit.
I would appreciate it if someone wiser than myself could take me under wing and help me to diagnose and repair my drive so I can enjoy at least 1 more outing this year before winter hits.
Thanks for listening to my tale of woe. I await the sage willing to accept a new apprentice.
Bob
BUT...
But I digress...
Bob
