Mako236@WYC
I just installed a new Honda water pump kit and OEM thermostat in my BF 40A.
With ear muffs on and the cav plate intake taped off, I ran the engine for 10 minutes with a steady, strong discharge from the water tell-tale. I stopped the motor. When I restarted it 30 seconds later, there was no stream from the tell-tale and it smelled like the impeller was burning. I stopped the motor, pulled the thermostat (looked perfect), pulled the hose off the tell-tale and blew into the hose. It was clear. The intake screens are clean and there is plenty of water flow through the ear muffs.
When I had the gear case off, I flushed water down through the thermostat housing and it freely flowed out the bottom of the middle unit.
Any suggestions what the issue is? Should I pull the gear case and inspect the impeller? Try again with the thermostat out?
I've done this maintenance many times and never had this issue.
Thanks for your help!
