meandmyharley
Hello everyone! My name is Bill, and this is my first time on this forum. I purchased a 1978 25ft pontoon boat, with a 1976 Evinrude 70HP, back in June. I used it a couple of times, was not happy with it. It got up to a whopping 4MPH. I started to do a lot of research and talking to people. With that being said; Here is what I have accomplished so far! I started by stripping it down to just the pontoons and the crossmembers. It had two layers of 3/4 pressure treated plywood and 18 pressure treated 2X4's. The total weight in lumber was 860 pounds! I re-installed 3/4 inch Marine grade plywood. (one layer)! All new wiring, and new carpet. Total weight of all of the new decking was 300 pounds. needless to say, she its much higher in the water, now! I have done a lot of work on the outboard as well. I purchased a shop manual. Cleaned the carbs, compression check. All three cylinders are within 5 PSI. at around 120. replaced two of the coils, linked and synched, according to the manual. I also installed a Tach.
Now for my issue, the prop that came with this motor is a 14X19. The boat now reaches 20MPH. which is plenty fast enough. But the motor only reaches 3600 RPMs. I have found where WOT is 5500RPMs. supposedly to make the powerhead run as efficiently as possible.
Which way should I go with changing the prop to get the extra 1500 RPMs? The local marina here, Smith Boys/Jansen refuses to work on it and even has been reluctant when I have ordered parts. So I am kind of lost here. I cant just start buying props until I get the right one. Unless where ever I buy them has a very easy return policy. Any suggestions? Thank you, Bill
