I would like to introduce myself, first time poster long time viewer. Please have patience with me I will be posting a ton of posts over the next couple months during my project. I have been working on boats since I was 5 with my dad first handing him tools then as an adult pretty much my whole life. I am not a professional in any means just a guy who loves working on boats and I would have to rate my experience a little above the average DIYer. I just purchased a 1988 28’ Marinette with twin 318’s in it that needs a ton of work. The boat has not been used in a few years one motor full of milky oil, other runs fine (450 hrs on it). I purchased a set of 1973/74 (forgot the exact year) fWC’d LM318 Chryslers from a gentleman who had them professionally rebuilt 10 years ago by a reputable marine engine company that has been in business for years, but he never installed them (boat got vandalized). The previous owner provided me with about 8k dollars in receipts (all new manifolds, engine rebuild receipts, etc…) of what he paid to have all the work done (of course I didn’t pay this since its been a 10 year lapse). They were kept in dry storage, fogging oil put in cylinders, motors hand turned a couple times a year with plugs out, etc….. He basically when the rebuild was done he went to the rebuilder, motors were started tuned, then the rebuilder fogged engines, winterized motors (drained all water from manifolds, antifreeze etc…) and the owner put them in his heated shop.
I have old motors removed from boat. And I am starting to work on getting motors ready for install.
This is what I am doing to the old/new motors I just bought prior to installation:
1. I don’t like his FWC set up. This year motors has dual pocket pumps. He has another impeller pump on each motor, one pump for fresh water side, other pump for raw water side. This year engines did not have an automotive style water pump. I have been told I cant use the dual pocket pump for both fresh and raw water, because its not totally sealed and raw water can bleed through to the fresh water side. I don’t like having 2 impeller pumps, I am going to install an automotive style marine water pumps on the motors, and pull the brackets, single Sherwood impeller pumps, pulley arrangement from the motors I pulled out to put on the motors I will be installing. If I had the room in front of the engine I would install crankshaft pumps. I am just trying to simplify the design.
2. The original motors have original distributers, the motors I pulled out have a couple year old Mallory marine electronic ignition distributers. I am going to switch these out as well.
3. Fuel pumps, the fuel pumps on all 4 motors dont have the drain line from the pump going to the carb so if the diagram ruptures fuel can dump in bildge. I am updating fuel pumps. I am also adding fume detector in bilge as well.
4. Carb update. I have had great success with Edelbrock carbs, I am installing 2 1409’s 600 CFM on angled plates. Original carbs are carter afb’s, carbs on pulled engines are Holleys.
5. Alternators. The alternators on the original boat were replaced with NON marine ones so they are going by by. The ones on the rebuilt motors I bought are old 50 amp prestolites with a separate regulator. I am going to upgrade to at least a 90/100 amp, alts, upgrade orange power wire going to solenoid and change original 50 amp fuse to 90/100 amp fuse.
If anybody sees anything I am not doing right please let me know and give me some suggestions, just trying to make this boat run good and safe.
Look for multiple posts from me trying to get suggestions on different items.
Thanks in advance for any advice
KMD
KMD
