M
mike Keeley
Guest
I just had a 9.9bigfoot put o
I just had a 9.9bigfoot put on the back of my larger boat. Had it done with control in the boat.when starting I have to play with the choke till I can use the fast Idle. I make sure the fuel bulb it firm but it starta very hard. when I take it off fast Idle it stalls. When going in gear it runs fine but then going to neutral it stalls.If I keep pushing the choke it will run. The bulb seems to go soft. They hooked my fuel line for the motor into my main fuel line in the seperator so I could use either tank.sounds like the motor is starving for gas???
