speakrdude
So here's the story. I'm sure some of you may have seen this on some other forums, but I am still looking for an answer or suggestions.
Boat: 1988, Sea Ray Sundancer 300 with twin, 1994 Merc 5.7's, Alpha 1, Gen II's.
Port engine seized a couple of weeks ago. 1 of the 2 engine rear mount bolts, absolutley frozen. Had to cut off the head of the bolt, thereby destroying one of the rubber bushings. Took about four hours to drill, pound, the old stud out but got'er out, cleaned up ready for new engine.
Ordered new bushings kit.
New Bushings are a little different now. No more spring looking lock washer. Had the machne shop remove the old ones from the flywheel housing and install the new ones per Merc. instructions provided in the kit.
So far, so good.
Set the engine down on her mounts, prepare to align, rear of engine too low! Merc. instructions said this may happen and provided 2 small washers, I believe called the shims. (.1" thick)
Much better, Can slide the alignment bar in with some force. Grease grooves on the top and starboard a little of the alignment bar.
The front of the engine obviously needs to be lower, trouble is, the front adjustable mounts are all the down!
Mercruiser has a Service Bulletin addressing this and says that with this set up, The front of the engine will need to be .272" lower than before, using the washers, .680 without using them.
So, how do we go lower? Can we add more shims to the rear? Do I go so far as to (Router) lower the stringer blocks?
Suggestions?
Thanks.
Jim
So far, so good.
Suggestions?
Thanks.
Jim
