jwatson355
Been working on my 4.3 volvo. Replaced fuel pump and carb. Still does not right and was looking into the ignition. I would like to make it a bit less complicated by switching to an HEI. Am I going to run into problems?
What is the actual problem? Please do not purchase anymore parts until we help you figure out what the problem is.
I believe the distributor you have is a HEI does your cap look like this http://www.ebay.com/itm/QUICKSILVER..._Accessories_Gear&hash=item5895f656c4&vxp=mtr
Before you purchase a distributor you may not need, Get a vacuum gauge, install a tee fitting in the fuel line between the tank and the filter. Run the engine and see if you are pulling an excessive vacuum on the fuel line.
Problem sounds like fuel.
I agree with Chris on this.What is the actual problem? Please do not purchase anymore parts until we help you figure out what the problem is.
What is your 1994 engine model number?
Your ignition system may be Volvo Penta's EST (electronic spark timing).
I think your right. Can those not function correctly or do they work or not work?
