skip_evans
"Hello everyone,
I just pu
"Hello everyone,
I just purchased a 1983 Imperial V 192. It has a 6 cylinder Mercruiser with an Alpha 1 Outdrive.
While out on the river yesterday I noticed the boat seemed sluggish, and the rear was sitting low. I removed the engine cover and found water deep enough that the drive belts were spinning water everywhere. I discovered that the bilge pump was not working either.
Where should I start looking for the source of this leak? Also, I want to say that the drain plug was in. Could there be any damage to the engine because of this? I don't know anything about boats. Is this just a normal amount of water entering the boat after 5 hours on the river, and a new bilge pump is the solution?
I'm not sure if I should ask about another problem in the same post. I apologize in advance if I'm not following protocol.
The tachometer, oil pressure, and trim gauges are not functioning. Is this problem solved by replacing the gauges the majority of the time?
Thanks, Skip"
I just pu
"Hello everyone,
Thanks, Skip"
